kchap
- Peculiar, MO, USA
I will be starting a panel build this spring that uses a Hoffman flange-mount disconnect enclosure with an Allen-Bradley 1494U (400 Amp) disconnect switch. It has been several years since I last worked with a flange mount disconnect. Looking at the install documentation for the switch, it looks like I will need to weld the door catch bracket to the door. Before I get into this, I want to make sure I avoid any surprises in regard to bracket position or how it fits with the defeater bar. Are the dimension in the 1494U installation instructions reliable, or should I expect to tweak them a bit? Is there anything else I should watch out for?
