electric heat strips
Hi Jersydaze,
One of the first things is to find out what the Climate Zone is in the project location. If the State has energy requirements, that will dictate heatpump sizes and heat strip minimums needed. Most heatpump backup strips come in 5 and 10 kW sizes for most brands purposely for dual element staging. Depending on your climate zone, equipment per
location will vary. So ask an HVAC sub their take for heating needs and go from there.
The house design also dictates what size those heatpumps are going to be, old method of sf and volume are being changed to State energy envelope design sizing that includes glazing, wall thicknesses, insulation factors, all for determining space environment conditioning. A 4500 sf vaulted ceiling house in the CA high country would need around a 4.5 to 6 ton system for both heat and cooling efficiencies that won't break the bank. I found it is harder to cool than heat a house using heatpumps in certain areas.
I hope this helps. rbj
