Coppersmith
- Tampa, FL, USA
- Electrical Contractor
I went to see this yesterday. A HI found the main lugs were double-tapped. The main panel is on a pole outside and feeds this 200 amp subpanel. The tap goes to another 200 amp subpanel beside it.
I'm not sure how to fix this. I think the easiest solution would be to have two sets of lugs in the panel. Do they make double lugs for SqD MLO panels? I thought about using Polaris connectors but there doesn't appear to be enough room. This panel is jammed with 41 circuits, mostly twins. The only other solution would be to intercept the bottom fed feeder in a trough and refeed both panels which would be very difficult because:
* The panel is buried inside a 12" deep kitchen style cabinet. (This is the laundry room.)
* There is a 12" deep counter and floor cabinet below it.
* There is a tile backsplash.
* Behind these panels is the kitchen so I can't work from the back side.
Your thoughts?
P.S. There are numerous other problems with this panel (which I'm sure people will mention). If I had to get it inspected I doubt it would pass.
Your thoughts?
