Re: Double tapping on a circuit breaker
Mike, I think if we are talking about stranded it would definatly need to be evaluated. My reference to the screw goes back to my engine building days as far as stretching threads either in the seat or on the bolt. I allways thought that was hearsay too.
bhp, any mechanical connection will change over time. When retorqueing, you would need to go back to the same conditions (ambient temps for example) that were present the day it was first done to get an acurate feel of how much change occured.
Unfortunately, "expense" is a driving factor in competitive bidding. I know you are looking at a single installation, but let's say you have bid a subdivision, you have to look at savings that would be allowed by code. Also
. 2 opinions, two good ways
I agree
Now let's look back at Tony's question. Yes, by the code, if the breaker is listed for two wires it is not a violation, and if it was written up Tony is wrong.
What this means Tony, is your job has just gotten harder. You must now educate yourself as to which can be double tapped.
Roger
