fredspence1
What's wrong with these pictures?
Sierrasparky said:Yup last time I checked Sq D QO were rated for two wires. This gets those home inspectors every time.
Dennis Alwon said:If one of the wires is stranded and the other solid , then you would have a problem. In either case I find it easier ti just out a pigtail and wirenut the wires together-- one under the breaker. Trying to prove an older panelboard being compliant may be an issue. If this is new then it would be easy to find the info.
K8MHZ said:Some breakers are listed for use with two wires. If it is not marked on the breaker seek out the mfg. web site and it should be on there. Some are even listed specifically for use with stranded and solid under the same tab.
Yours looks like it may be designed for one or two wires.
dnem said:When you say "under the same tab" are you referring to a breaker with a "foot" or tiny plate attached to the lug screw ? . Or possibly to plates that squeeze together ?
I was under the impression the the breakers that drive the screw tip down onto the wire are single wire only rated.
480sparky said:Is it just me, or are two of the breakers that are doubled up tripped?
TOOL_5150 said:Looks like 2, possibly 3 breakers are tripped. GOt to love the visitrip feature.
~Matt
JohnJ0906 said:At the angle the pictures were taken, the visi-trip red might be visible even with the breaker on.
480sparky said:True, but then most of them on that side would be visible as well, wouldn't they?
