DPDT Rib Relay Controlled By 3-Way Switch
Here is one that requires a pulse input, apply and release power once to latch, apply power the second time to release. GE junk. A two wire module is required if you have maintained voltage. They were trying to compete with Square D, as the contacts can be changed from N/O to N/C by fipping the contact block.
Why do you say junk? They fail more often than the Square D version?
