I've got a situation where heat trace was installed on drain pipes for an elevated podium walkway. It was installed about 12 years ago, and I've been told that it never worked properly. My question involves the design of such a system. There is no heat trace in the walkway itself, just the drain pipes. This walkway is about 16-18 feet wide and hundreds of feet long. Now, in order for this system to work properly, I contend that heat trace is needed in the walkway as well as on the drain pipes. I'm not 100% sure on that, hence my question. Can this work well the way it is designed now?
