jmellc
- Durham, NC
- Facility Maintenance Tech. Licensed Electrician
If you do a lot of drilling wood studs in tight corners, try the Irwin Speedbor Max bits. I have a 3 set of 1/2, 3/4 and 1 inch, bought on special 2 sets for $15 last year.
These are very sharp and cut easily in new or old wood. 4 inches long. On a battery drill, they will fit nearly any tight corner. The shaft is a bit fragile and will easily bend if you hit nails, so try to avoid them.
