Re: Drilled holes in joist in residential.
In a house in my humble opinion, I think it is overblown for the most part. Like somebody said in an earlier post , if it is a 2" hole with every cable in the house run thru it, I would be concerned, especially if they did not fan out the wires in between joists. But in a commercial installation, now thats a different ball game all together. I would not be suprised at all to find overly hot cables if run in multiples of over 3 cables in the same holes. A lot of stuff in a commercial installation is up and running all at the same time during business hours. And the lighting loads are generally heavier. In my house there is over 50 receptacle outlets that do not generally get anything at all plugged into them. They are there to comply with spacing requirements, with some extra ones not required, but hey I wired my own house. I doubt there is a restaurant in the whole country that has so many receptacle outlets that go unused. Or a print shop, or a barber shop or whatever. Whats my point? Dwelling circuits for the most part are pretty much unloaded, mostly. Therefore, not much heat to dissipate on the cable . There ought to be some relief exemption for dwellings.
