automate0042
Periodically I need to drill a pilot hole in a ss enclosure- grab the drill bit set and fight it tooth and nail. What's the best type of drill bit to use in ss?
Absolutely:happyyes:More pressure, less speed. Not the other way around. That's what will destroy your drill bit. I've seen too many good drill bits burned up .....
Thanks for the responses. That's why my index is usually shy the little ones- easy to get in a bind! I was going to refill my index and realize that there are different types i.e. cobalt, 135 deg. angle, etc. etc .
I have a true cobalt set of drills not cheap ones that claim they are cobalt as many you find in the big box stores are, yes they are very pricey but worth the price if you drill hardened steel or SS often, just watch out for sales gimmicks as there are many who use the word cobalt as a trade name or other method of deception such as having a low amount of cobalt like only 3% and are not true cobalt drills, also the set of carbide quick change hole saws I use will also drill SS and have true M42 cobalt pilot center bits, it is always best to not over heat a drill bit when drilling any metal as the bit will loose its temper and not hold its edge.
Avoid any drill bits that are coated as if you intend to resharpen them the coating is lost, cobalt drills come in two grades M35 (5% cobalt/hardend tool steel) and M42 (8% cobalt/hardend tool steel) the latter being better for more harder metals such as SS, while titanium drill bits are alittle harder but they only are coated and will loose there hardness when they are resharpened while a true cobalt can be resharpened the life of the bit.
