growler
- Atlanta,GA
This has the added benefit of not needing to use a pilot drill for the hole saw. Use a smooth steel rod instead.
Either that's a non sequitur or you didn't see what I was saying. Since you already plan to have the pilot hole drilled with a separate drill, you don't need the cutting edge and flutes on your hole saw pilot. If it's a smooth steel rod, it works more smoothly in your predrilled pilot hole and has less chance of wallowing it out.
I didn't catch your meaning right off either. Once I read the next post it makes perfect sense.
A good steel rod wouldn't be as easy to break either.
There are lots of neat tricks out there is a person is willing to try them.
