Why can't you attach to the existing wire? Does the inspector wish to see the tops of the ground rods?
Their is no existing wire, im adding a new meter and disconnect.
I have never been a big fan of driving ground rods without knowing what lies below. I have a job coming up where i have to add 400 amps to an existing service on the back of a shopping mall. The asphault goes right up to the building. I will hammer drill through the asphault then drive my rod. Any suggestions or tips on how thick my gloves should be or better yet how long a handle i need on my sledge lol. Im sure many of you have done this before hoping their wasnt a sewer line or worse a primary lying below YIKES!
Even with a dig alert or locate, you can still get burned..almost literally. Some yeas ago while working with an EC on a light commercial install, I was helping to drive a new ground rod. The nearest locate was several feet away so we thought we were safe.
My co-worker was on a short ladder with the power hammer and I was holding the rod, thankfully with rubber gloves and leather over gloves on.
After we got about 3-4 feet in, I noticed what I thought was smoke coming up around the rod, which I dismissed as the extremely dry topsoil.
Well, a very loud bang some distance away caught our attention, as we had driven the rod right through a buried 12kV feeder..the bang was the cutouts on the pole blowing.
Luckily for us, we were both wearing gloves, and since the locate was obviously wrong we didn't have to pay for the damage, but we still had to deal with the fallout of all the angry businesses on that UG that we penetrated.
Locates provide a fair degree of clearance, but NEVER take for granted you could still hit something..so wear protection and go carefully!
So why are we adding ground rods to an existing system? wasn't there grounding electrodes installed for the original service? they can be used for the addition?
Edited again, didn't see the last page
I had a locate that they marked the gas line going to the property that I was working on, but failed to mark the other line that crossed that property from the same tap point on the street main going to the property next door. Got the trench all the way from the service to within 15' of the pole, turned the trencher around to trench back from the pole, hit that gas line right at the intersection of the trench. The utility locate service tried to weasel out of it by saying part of the trench was on the other property. Problem was, were I hit it was still on the property that the locate was called in on. The office never did say whether we ended up paying or not.
Good idea..... this might sound ignorant gut can they locate through asphault? and if so do you have to pay for the locate?
Was your proposed trench line marked with white paint / flags?
I did look today at the other side of the building at the exact
same setup as I have on my side. Some other contractor added 400 amps to their bank of 6 meters (after the pour of concrete and asphault). They did not have a ground rod present, so makes me wander where they picked up their ground maybe all the way back to the main 800 amp switch, and the only ground I see present their is a building steel bond. I spoke with a electrician who was over the building of the service and he said they have a delta ground system on the rods. Any input would be greatly appreciated.
