TNGuy81
- Nashville TN
Hey to all and I apologize if this has already been asked and I am sure it has. I thought I had a pretty good grasp on bonding and grounding but here lately im questioning that. Anyway.
I have a old home with a 4 prong dryer receptacle in it and a old dryer that had a 3 prong whip on it. I switched the whip out to a 4 wire and made it up and noticed the 4 prong receptacle had only 10/3 (no ground) to it. I am aware this is not code but I am renting the place and it is what it is. I wired the 4 wire wipe up and disconnected the bonding jumper then just attached the ground wire to the frame. Was this the right thing to do? The fuse box is bonded at the main and I thought this was the safest way to do this. I dont want the neutral back feeding and someone getting shocked on the frame of the dryer. So its really only got hot/hot/neutral... but its bonded at the panel so the neutral serves as a ground also correct? Or do I need to put the bonding jumper back on the dryer??
Thanks in advance
Thanks in advance
