electricman2
- North Carolina
- Retired Electrical Contractor
Anybody ever run across this? Dryer circuit with 10-2 w/g NM. House built probably mid 70's. Got by rough inspection I guess.
electricman2 said:Anybody ever run across this? Dryer circuit with 10-2 w/g NM. House built probably mid 70's. Got by rough inspection I guess.
220/221 said:NM as opposed to SE.
It is a technical difference IMHO.
Okay, so when is that not dangerous? When is a double-plug-ended cord okay?LawnGuyLandSparky said:This is very dangerous, and makes backfeeding a genset through the dryer receptacle all the more dangerous.
I know you dont mean male/male we are here to learn more ways to skin the same cat we are cat skinners at best.LawnGuyLandSparky said:This is very dangerous, and makes backfeeding a genset through the dryer receptacle all the more dangerous.
iwire said:Still not sure why that is wrong but if it was SE it would be OK. :-?
hardworkingstiff said:In the 70's in the Tidewater, VA area, 10/2 w/grd NM was not allowed but 8/3 SE (AL.) was allowed. I never understood the difference.
LarryFine said:Okay, so when is that not dangerous? When is a double-plug-ended cord okay?
augie47 said:The oldest Code I have handy is 1990 and the requirement then was an INSULATED grounded conductor unless SE cable was used...
In the 10/2, the bare ground wire was used for the neutral. In the 8/3, the neutral would have been covered/insulated.
