Meaning your existing outlet is __?__ wire ?I am getting a new dryer and it going from a 3 wire to 4 wire .
. WE have 208 volts and the dryer will be 230 volts . I believe I am alright but I like to make sure.
Thanks for you help.
I would buy a 208 volt dryer.
I am getting a new dryer and it going from a 3 wire to 4 wire . WE have 208 volts and the dryer will be 230 volts . I believe I am alright but I like to make sure.
Do NOT go to a 4-wire dryer plug. If your existing receptacle is 3-wire, that's fine just get a new 3-wire cord & plug for your new dryer. The 4-wire requirement is code for new dryer/range receptacle installations, not a new appliance installation.
Why would you say DO NOT,,,,,do something safer,,,I can see you say you may not have to,,,but don't say DO NOT . Especially when we all know it's safer
It's not safer if the existing circuit is 3-wire and is re-used. He was saying that the cord should match the circuit.Why would you say DO NOT,,,,,do something safer,,,I can see you say you may not have to,,,but don't say DO NOT . Especially when we all know it's safer
Because 2 recent experiences have taught me that HD clerks and appliance salespeople are seriously misinformed about the code change and how it affects existing installations. They are telling buyers of new appliances it is a "must do" code change, and it is not.
A 30a 240v GFCI breaker would also be a "safer" way to protect a clothes dryer, is this part of every sales shpeil as well?
A new circuit, that is, not a new appliance.. . . but it is not safe enough to install it that way anymore.
Receptical must match the circuit. 4 wire recep on a 3 wire circuit gives a false sence of security. The next owner will assume it is done correctly.
I have wired many dryers with 10/3 plain.. no ground............
