enireh
- Canyon Lake,TX
220 volt dryer has 12 to 13.5 volts on vent/duct to ground we get a little buzz if we bump the garage door while touching the duct
Lets not pull trigger too quick on removing bonding jumper, if it is an allowed three wire circuit, the bonding jumper must be installed, and some voltage on the dryer frame would be normal in that case, it just ordinarily wouldn't be that high so we need to find out why it is that high.Definitely sounds like objectionable current. Verify by turning the circuit to the dryer off and testing. Then follow the above advice, removing the bonding jumper
Sent from my SM-N915V using Tapatalk
