Phillip Land
- Rome, Ga, US
Hi,
I'm hoping that I can get some advice on what's causing a GE DF breaker to trip. I installed a 20a circuit to feed 2 duplex receptacles under s sink - one for a dishwasher and the other for a disposal controlled by an air switch. The breaker only trips when both appliances are plugged in but not running. It trips within 5-10 minutes. It does not trip when either appliance is running nor does it trip when one or the other is the only thing plugged in. I also tried using another DF breaker in the panel and it does the same thing.
My gut tells me that it's the gfci component that is causing the problem but for the life of me, I don't know why it would take both things being plugged in for the breaker to trip
I would greatly appreciate any ideas as to what is going on here
Thank you,
Phillip
Thank you,
Phillip
