Hi All,
I have a ductless mini-split type A/C unit. This unit condenser circuit feeds the indoor unit (1 circuit) per manufacturer. My question is how do you typically calculate the voltage drop for something like this and how are they typically connected? For example: The condenser on the roof (above 3rd floor) and indoor unit is in the (1st floor hallway).
Distance: (Panel to condensor 50feet) ----- (condensor to indoor unit 50feet) ---- (Panel to indoor 10feet)
Assume the panel that is feeding the condenser is also on the first floor. Is the circuit going from the panel location to roof condenser to indoor unit?
Or is the circuit in the first floor being split on 1st floor where one is going to condenser (roof) and one is going to indoor unit 1st floor?
The voltage drop will be much higher if it is a full loop.
Thank you,
Thank you,
