Re: Dumb question but I'm serious
These have either Neon lights, or LED's. I think it is possible for either to survive 220 volts (but it would depend on how long it was plugged in, and the values of resistance used - like Physis said).
To picture a schematic of one of these testers, draw the 3 wires to the receptacle - line, neutral, and ground. Draw a green light between line and ground, and a green light between line and neutral. Draw a red light between neutral and ground. (Assume the lights are 120v, and don't need resistors, and assume they can survive 220volts.)
If the outlet was wired with 220V, then the neutral would be conected to a second phase. The two green lights would still light (somewhat brightly) and the red light would also light up at normal brightness. Thus, you would know something was wrong by the red light.
Steve
[ June 03, 2005, 01:09 PM: Message edited by: steve66 ]
