Dwelling Unit with 2 meters service upgrade
RBGS
Boston, MA
Hello,
I need to do a service upgrade for a house from 100A to 200A. I have done this before..4/0 ALU....bla bla bla
However, I have never done one for a house that has (2) meters. The customer is requesting to replace both meters and both panels from 100A to 200A.
My question is the following:
1)Can I use 4/0 AL for my SE cable to power both panels? or do I need to upsize the wire?
2)Do the meters get wire in parallel?
3)Do I need to do individual ground rod to each new panel?
Any help or suggestion will be well received.
Jason
One meter appears to be from a solar system? That means only one is from the PoCo? Wouldn't the latter be the only one you can really upgrade?
Or am I missing something in that picture? Hard to tell where everything is going.
Can't read the labels on the subpanels; are they pertinent?
What you have there Jason, is a net meter, which are wired backwards juxtaposed to a normally wired meter, and tagged into the normal 100A house meter. ~RJ~
I was assuming that there was one meter for each panel...since they both have independent SE Cables going into each panel.
Yeah, not enough information to properly answer the question. This is a basic residential job so I am surprised that you would have to ask that question. Did you not look at the job close enough before you placed your bid/estimate and pulled a permit?
I'm not being a hard ass, I'm asking some legit questions.
I think that's probably the much better and accurate way to describe what I was trying to put out there.
yup, I doubt i'd have much of a career in tech support Mac...
Is that meter provide by the solar company or the poco?
net meters are usually via the prevalent poco , 'cuz they want to make sure they're not giving back what consumers are $$$'ing.
~RJ~
