E=IxR
Re: E=IxR
To answer the ORIGINAL question that was posed, "what does the I stand for"...
The "I" in Ohms Law is derived from the German word "Intensitat" (the "a" in this word has a double oomlaut) which means INTENSITY. Which is typically used for the Amount of current (the amount of charge Q flowing per unit of time t)
i(t) = [dq(t)]/[dt]
So..tell your daughter and her teacher same. Ohm's work was originally published in "bavarian" that's "German" to the modernist.
Now you all know and/or remember...right?
Re: E=IxR
My 2 cents worth re. the symbol'I':
"The symbol typically used for the amount of current (the amount of charge Q flowing per unit of time t) is I, from the German word Intensit?t, which means 'intensity'."
The symbol for the charge on an object is Q (or q), and the unit of charge is the coulomb, (C).
And,a coulomb?: the quantity of electricity involved when a current of one ampere flows for one second.
One coulomb=6.3x1018 electrons (elementary charges).
Dave T
Re: E=IxR
100,000 electrons = 1 columb
1 columb per second = 1 ampere
100,000 electrons per second = 1 ampere
Don't get your units mixed up when changing subjects
Re: E=IxR
Sorry, but no cigar for either of you.
The charge on one electron is,
-1.6E-19 Coulomb,
therefore,
1 Coulomb is the charge on,
6.25E18 electrons.
Powers of ten may be represented as follows,
E18, 10^18, or 10**18 all mean 10 to the eighteenth power.
Re: E=IxR
By lesliek:
i(t) = [dq(t)]/[dt]
I've looked around quite a bit trying to find where I originates from and haven't been able to find anything. As far as I can tell Ampere was using I during his experiments. I'm not sure about this but I think it was before Ohm's law.
Can you provide a reference or a link?
