karl riley
I am starting a new thread as an offshoot of the grounding electrode thread. Brian John, you mentioned that there would be problems if earth resistance were very low. So here is the info I am going by at present. I am open to correction.
The resistance of earth is reported by university researchers to be negligible; practically speaking, zero. This is because the cross-sectional area is unlimited.
When we measure earth impedance we are just measuring the impedance of the electrode/earth interface. Once it gets into the earth, further impedance is negligible.
This is the only way the SWER systems work for long distance primary distribution lines using the earth as the only return path to remote locations. They have to keep the transformer grounding electrodes to low values (I think it is 5 ohms). Not as efficient as three phase with neutral, but workable. They do it to save in cost of installation.
Brian, I agree that there would be problems if our grounding electrode impedances were very low, since neutral would be coursing all over the neighborhood, not just in the water pipes. I had a thread on this but got little discussion.
So does anyone have any experimental data to either confirm or deny this earth impedance info? It was a surprise to me.
Karl
Karl
