IrishRugger
I am bidding a one room addition to an existing home, as an option the home owner would like in floor heat for their tile floor. The room is about 320 square feet. Warm Tiles does not make a kit that would cover the entire area. They suggest combining two heat cable kits.
Using two 240V kits, if the total amperage exceeds 16 Amps but does not exceed 24 amps they require a relay kit they manufacture in addition to their Programable thermostat. I spoke with their Tech support and they told me that using two
DFT2137 kits would cover approx 290 to 300 square feet, and both kits combined draw only a total of 15 amps in which case both cable kits could be terminated on the load side of a single 240V programmable thermostat that is good for 16 amps.
My questions are:
Has anyone ever done an installation using two cable kits and one thermostat?
If so How did that work out were there any problems?
Does anyone recommend using the relay kit in lieu of what Tech support says?
I have installed a number of these cable kits and this is the first time I would have to combine two of them, I'm just looking for any heads up advice you may have to offer. Thank you
My questions are:
