JoeTroubleShoot
- MA
http://ecmweb.com/fire-amp-security/electrical-forensics-case-service-cable-arcing-incident
Just curious if anybody read this article. After I read it, I thought maybe they missed what another possible cause of the fire was. It's seems more possible that the neutral burned clear towards the transfomer and welded to a hot leg towards the house giving the homeowner 240v on half of the 120v circuits. That would explain them being part off when the handy man showed up and not notcing the arcing until the whole service eventually burned down.
I've seen it happen a few times before and it had the exact same effect. You end up reading 240 to ground on one leg, zero to ground on the other, and 240 leg to leg. Ground rod plus regular factors did not create enough current to trip the primary fuse and randowm fires broke out throughout the house. Just curious if anybody else thinks this might have been over thought or if it was thought about and ruled out.
