winnie
- Springfield, MA, USA
- Electric motor research
I'm not a utility engineer; I only know what I've read and what I've seen on the poles that I've looked at.
To be clear, I'm talking about the distribution level voltages on poles, the last 'high voltage' prior to the transformer which feeds the customer.
Most of the transformers that I've seen have a single HV bushing, and the HV coil has to be connected between that terminal and some other low voltage terminal. My understanding is that this is usually the grounded can itself. In this case the 'ground' conductor which usually runs along the poles is being used as the neutral conductor for the distribution system.
-Jon
-Jon
