Re: EGC attachment
Mdshunk
What I am about to write has no bearing on you - it is a statement using your post as an example. I am not writing this because I feel this way, but I want to pass on some info
"They're no reason why an ordinary mechanical lug couldn't be used. After all, they're listed too. It's not like you're asking if you can wrap the EGC around the wood screw that's holding the panel to the wall. I've even installed generic ILSCO ground bars in obsolete panels that were being refed as a subpanel. That's one of the reasons they make the generic ground bars. Sand the paint off, tap mounting holes, and mount the bar."
This is basically how we have installed these bars for years, and in general it works very well.
but...
There is an issue here to beware of. That is these forensic insurance people who come to a job when something goes wrong. (I know, a small percentage of installations, but something to be aware of)
They go into the jobsite and record
ALL OF the violations/issues on the job - it is called building a case.
Then in court the (well planned and informed attorney) will start asking you questions - he is quietly assessing your knowledge and will prove beyond a doubt whether or not you actually know what you are doing. They can make a mockery of you in a very short amount of time and you will leave the stand wondering what just happened
- whether or not you are good at what you do.
Manufacturers test their equipment with specified parts. Using some other parts that have not been tested as being suitable (whether you like that or not, it is a fact they use in court) will lead you into problems, if there are some other problems that bring you to court - which happens to a small percentage.
The only problem is .... will you ever be that small percentage??????
I can say that I have been on the stand many (too many) times in the last few years, so I have personally been through this. I was surprised the first couple of times at how much time I spent on the stand going over my history - when I thought I was there for other reasons.
Just something to think of when you install stuff in the future.
