EGC attachment
Re: EGC attachment
t is a Midwest metered panel. I tried a lug like infinity posted and it doesnt fit. And the type of ground bar that hurk 27 describes won't work because this is a 2/O gec.
gserve in the first post you identified this conductor as an equip ground, then it is a gec. Which one is it?. It makes a difference regarding this posting.
Re: EGC attachment
Originally posted by gserve:
I have a situation where a EGC will not fit on the neutral bar in the service equipment. I have tried to find a listed and same manufacturer add-on grounding lug kit to no avail.Except for the article 110 listing requirement issue is there anything wrong with installing a bolt-on lug of proper size and bolting it to the side of the panel with a nut and bolt? Code referances please. Thanks
It is a Midwest metered panel. I tried a lug like infinity posted and it doesnt fit. And the type of ground bar that hurk 27 describes won't work because this is a 2/O gec.
equpment grounding conducttor(EGC)
:confused: :confused: :confused:
[ November 02, 2005, 04:39 PM: Message edited by: jwelectric ]
