- Tennessee NEC:2017
- Semi-Retired Electrician
If you have a circuit that is completely disconnected from the device and wires properly capped and then disconnected at the breaker, would there be a problem if the EGC from the circuit was left connected to the ground bar in the panel? The grounded (neutral) conductor also disconnected, only the EGC still connected.
