All I hear from electricians these days is how it doesn't matter how well they run their conduit or make up their fittings because it's gonna have a green wire in it anyway.
Im say that if a pipe is subject to damage and accessible to workers that might come in contact with it (in the locations listed above) in the event of a ground fault a egc of the wire type should should be present
Totally agree with you guys here. Never understood how workers who do sloppy pipe work with all these loose fittings always somehow do good work on the wire egc connections.
Based on my experience, i see many many more sloppy/impaired wire nut connections than emt fitting connections, so i trust the pipe egc a lot more than the wire egc as a fault current path.
