Hi, I installed a couple of GFCI receptacles in a garage. There is a Stab-lock subpanel on the inside wall coming from a 200A main panel. I installed a 20A in the stab-lock subpanel and(3)#12 conductors (white,blk & grn). I believe that Art 250.118 says I can use the emt as the ground, right? I installed a #12 ground wire going out to the GFCI receptacles and thinking it's already grounded from the emt and there is no ground bar inthe subpanel should I just terminate the ground directly to the subpanel?? Thanks, Jerry
