I sure hope I don't open up any old wounds here.
I have a business occupancy, with a backup generator for life safety type loads.
At the points of exit discharge, I have an egress lighting fixture above each egress door. I have these fixtures on an emergency branch circuit. In the electrical room, I have split this circuit into two parallel paths; one path goes through a lighting control panel relay (clock control). The other half goes through a normally-closed relay, controlled by a normal power branch circuit.
In an emergency condition, the light will always come on, regardless of time, but I can imagine someone at the user level not programming the lighting control panel correctly. This might make the egress lighting malfunction under normal power conditions.
In other words...can a fixture function as emergency, egress, and still be controlled under normal power conditions, or does it have to be foolproof? Any life safety codes obviously broken?
Thanks.
Thanks.
