I have an issue of deciding whether to install elbow arrestors in addition to my present load break elbows that are already in my design for my pad mounted transformer enclosure. I must install a second ground rod if I install the elbow arrestors since I am not installing a ground loop or counterpoise (in that I am grounding my concentric nuetral, XLP cable everywhere is the reason I do not need the ground loop or counterpoise). This is my understanding.
I should refer to a tech rep for transformers and probably will, but thought I would ask the forum if the elbow arrestors are the same thing as the load break elbows in the pad mounted transformer enclosure?
