mkgrady
- Massachusetts
I have a customer that wants electric heat in their basement. I never really learned how to calculate this...just always guessed and the rooms were always finished rooms with insulated walls. This situation is for a basement that is not finished or even insulated, in fact the heated space on the first floor above will be insulated from the basement. The basement ceiling is going to have fiberglass insulation placed between the joists.
It sounds like a wacky situation but this home is about to be converted from a summer cottage to a year round home. The owners goal is to keep the pipes in the basement from freezing. In previous winters the place was just shut down and the pipes were drained to prevent frozen water pipes. His other goal is to keep the basement warm enough to be able to run a washer and dryer. I can't imagine doing laundry in a room that is only 40 degrees.
The house has cement block foundation walls that rise about three feet out of the ground. No insulation on the block walls. The space height to the bottom of the ceiling joists is five feet. The space is about 30' by 33' and the outside temp goes as low as zero Fahrenheit. He is right on the coast of Massachusetts so below zero pretty much never happens because the ocean moderates the temps.
Any ideas on how to calculate the wattage this will need?
