electricalperson
- massachusetts
are there any rules of thumb for sizing baseboard heating for rooms?
Yes, one watt per cubic foot works fantastic.
Um... no. Cubic feet is not square feet. At least not when I was in school.one watt per cubic foot? so a 2000 watt heater is enough for a 2000 square foot room? i dont get it
Uh-huh. That'll get you in good shape for most of the US. You can't size baseboard heat that accurately anyhow due to it coming in 250 watt steps. You might end up a foot short for a room in Minnesota, and a foot long for that same room in Oklahoma, but you're going to be in good shape for most places using this rule of thumb. The real way is to do a room by room Manual J calculation, which is about as much fun as stabbing yourself in the eye.sorry i misunderstood. so you multiply L x W x H of the room and thats the wattage you need for heat?
In your example, if I had a room that big, I might use a few sizes of heaters to put them under the windows. If there were 6 windows, I might use 6 3-footers to end up with the same net result. It's nice to wash the windows with heat. I have already had to use something like two 4-footers when one 8-footer would work, due to how furniture was going to be placed. Whatever adds to however many watts you want to get.thank you guys i understand now.
example: room 20 x 20 x 10 = 4000 cu feet = 4000 watts of heat needed
4000/1200 = 3.33 = 4 1200 watt heaters required
i was just wondering because i had to install heat and the boss sized it and told me to install it
Baseboard heat is 250 watts per foot, with a couple weird exceptions:
The 2-footer is 400 watts
The 30" model is 500 watts
The 8-footer comes in both 2000 and 2500 watt
There is no such thing as a 7 footer, and nobody makes a 10 footer anymore now that you have the high-density 8 foot option.
Yeah, the 6 footers are 1500 watts each. If you mostly install 4 foot and 8 foot, that makes me wonder if they weren't sized by someone's gut feeling.i installed 6 foot heaters today. they were around 1200 watts. i havnt really installed too much of this so thats why i didnt know how to size them. the most common kind i install is 8 foot and 4 foot.
the room was toasty warm when i was finished![]()
Yeah, the 6 footers are 1500 watts each. If you mostly install 4 foot and 8 foot, that makes me wonder if they weren't sized by someone's gut feeling.![]()
Speaking of electric baseboards, the hydronic (oil filled) ones are quite nice. I don't know if they are sized according to the same rules but they are a cut above the regular baseboards if you can upsell them.
Expensive, but nice if want electric baseboard heat. but then again, thats kind of why it gets installed to begin with, CHEAP.
Yeah, sized the same way. They just keep the heat a little more even since the oil is giving off residual heat after shutdown. Takes a bit to warm up again, so the heat is gradual. Use a Honeywell LineVolt Pro thermostat on regular baseboard heat and you've accomplished the exact same thing but in a different way.Speaking of electric baseboards, the hydronic (oil filled) ones are quite nice. I don't know if they are sized according to the same rules but they are a cut above the regular baseboards if you can upsell them.
i had 4 heaters all controled by one thermostat. i used a relay designed for electric heat. it was built by white rogers
