gar
 - Ann Arbor, Michigan
 - EE
110327-1000 EDT
It is unlikely that the taxation will be via the KWH meter. More likely a fixed yearly figure associated with your license plate, or yearly monitoring of your mileage meter. It is already illegal to tamper with the odometer setting, and this is not causing much abuse.
GM is limiting Volt production to about 10,000 units this year if I am not mistaken. They hope it will increase in following years. Suppose that over the next 5 years the total number of grid powered vehicles of all manufacturers increases to 1,000,000 units on the road, and each extracts 10 KWH per day from the grid. Then the added energy load on the grid per day is 10,000,000 KWH = 10,000,000,000 WH.
From
http://www.eia.doe.gov/cneaf/electricity/epm/epm_sum.html
it appears the yearly production for 2010 was in the range of 300 to 300 terawatt-hours, or maybe 1 terawatt-hour per day. This is 1,000,000,000,000 watt-hours. Thus, the car load above would be about 1% of the total. Not any burden. Increase this to 10,000,000 vehicles and it is still not a big burden.
Check my facts and calculations.
From
