Well I tried, but I knew pollitics would enter, I even have a hard time because Politics plays a role. However the real driver is pure econimicsgeorgestolz said:And Dereck thought we could keep religion and politics out of this...![]()
Are you sure torque can't exist at zero RPM?dereckbc said:Without HP or rpm, you do not have torque period.
LarryFine said:Are you sure torque can't exist at zero RPM?
If you said you can't have HP without torque, I'd agree.
dereckbc said:Plug zero in the equation of:
T=(5252 x HP)/rpm
and see what you come up with.
winnie said:Internal combustion engines are always less efficient when operated throttled back. Using an oversized engine throttled back to move your car down the highway means that the engine fuel efficiency is much lower than it could be. I bet that Julie's 'vette would cruise down the highway at the speed limit with a 20hp engine in it, and get _great_ gas mileage. The car would also be virtually undriveable, because it would take forever to get to the speed limit, she could never actually merge with traffic, could never pass, etc. But it would get great gas mileage.
dereckbc said:Julie,
HP is relevant to the discussion. The reason is HP is an integral part of torque equations. You cannot have without the other. It is like saying you can have current without watts, not possible and violates laws of physics. T=(5252 x HP)/rpm. Without HP or rpm, you do not have torque period.
tallgirl said:You have your equation backwards -- HP is derived from torque. In an electric motor torque is the total of the magnetic attraction (or repulsion) between the parts of the motor. Since that attraction (or repulsion) can exist in an electric motor at 0 RPM, it's possible to have torque in an electric motor at 0 RPM.
I don?t know what else to tell you other than what we are discussing is right out of any electrical, physics, or mechanical engineering 101 book. You cannot have torque without HP and RPM, and you cannot have HP without torque or rpm. The two formulas are one in the same and interchangeable just like Ohm?s law.
T= (5252 x HP)/rpm
HP= (RPM x T)/ 5252
Plug zero in anywhere you want and you always get zero, the equations always have to be equal, or they are not true.
tallgirl said:(I'd also point out, that if you plug zero into the first equation -- T = HP x 5252 / RPM -- you don't get "zero".)
roger said:Julie, tell us what you get.
Roger
winnie said:An 4 pole 60 Hz electric motor rated at 200 hp and 95% efficiency will have a nominal continuous torque rating of about 600 foot pounds. Put this motor on an appropriate drive, and it will produce 600 foot pounds at 0 RPM (power output 0 hp, efficiency 0%).
tallgirl said:Infinite torque
But as Jon wrote earlier, an electric motor can produce torque at 0 RPM. Since HP = Torque * RPM / 5252, what's the horsepower? Again, as Jon wrote there is no horsepower output --
roger said:And so what are you saying?
Tell us in a numeral form what you get when you perform the equation
Roger
tallgirl said:Now, plug in some lb-ft per second and we get this --
1 lb-ft per second * 5252 / 0 RPM = infinite ft-lbs
Huh? some lb-ft per second indicates some means of time and distance like RPM, therefor your equation is not true as some sort of RPM (even fractional)would have to be defined.
x/o = error, undifined, or a computer freeze in a floating point processor.
dereckbc said:tallgirl said:Now, plug in some lb-ft per second and we get this --
Of course it's undefined.
But it's still possible to produce torque from an electric motor, or your arm, butt, or a brick on the end of a board, at 0 RPM. There's no power output, because the RPMs are zero, but that doesn't mean it's impossible to have torque at 0 RPMs.
Grab a beam-style torque wrench. Torque a bolt to 100 ft-lbs. Now, apply force on the end of the wrench until it measures 50 ft-lbs. Calculate the amount of horsepower you're producing at 0 RPM with that wrench.
tallgirl said:Certainly.
600 ft-lbs x 0 RPM / 5252 = 0 lb-ft per second = 0 horsepower
tallgirl said:Let's see if we get that back out ...
tallgirl said:0 lb-ft per second * 5252 / 0 RPM = 0 ft-lbs torque
tallgirl said:Where'd my 600 ft-lbs of torque go?!?
winnie said:Okay, now I am confused as to what the discussion actually is.
Is anyone here actually saying that electric motors _cannot_ produce torque at zero speed?
-Jon
Originally Posted by dereckbc
Julie,
T= (5252 x HP)/rpm
HP= (RPM x T)/ 5252
