Re: electric ceiling heat
I first heard about that stuff in the 60's. Even though heat prefers to rise, ceiling heat is remarkably effective. Many radiant heating (water pipes in concrete floor) systems work fine running the upstairs heat zone while keeping the upstairs and downstairs comfortable. Of course the upstairs will be a tad warmer. This works well if you have old people upstairs and young people downstairs-- assuming old like warm, and young like not as warm
Heat will try to equalize towards cold. The majority will rise, but a fair percentage will drop. Ceiling heat is effective, albeit a bit wasteful. It's just not as bad as we'd presume.
As for an old heat system in ceiling Sheetrock, I'd seriously consider junking it as it makes me nervous. I'd do some serious research on documented failures.
If this is a two-story home, and the bedrooms are on the second floor, the bedrooms are probably adequately and efficiently heated as they can rely on the first floor ceiling to pull the majority of the load and BTU delivery for both floors. Typically these systems are zone controlled by several thermostats (ala baseboard heaters).
Another safety factor is that with the large surface area, the surface temperature is very low. There should be low danger of wallboard paper ignition from spontaneous combustion due to charcoaling. Please do some research to confirm this, as this is only an opinion.
[ December 09, 2003, 07:03 AM: Message edited by: awwt ]
