weressl
Esteemed Member
That wasn't caused by this electrician.
That is correct Larry.
Suppose the homeowner had turned that breaker on. Would the person who left the feed unterminated be any more or less at fault?
Between turning on a breaker and leaving an equipment feed hanging with bare wires, the latter is the more negligent act, IMO.
The homeowner would be less liable - but not scott-free - than an electrician. The electrician knows, or should know, better. In this case he behaved like a homeowner.
That is why I said that the liability percentages between the original individual who disconnected the wiring and left it unsecure and the electrician who turned the breaker off would be determined by the court or mediator.
There was a court-case in upstate NY where an electrician got killed by an Elastimold elbow. The elbow was sliced open and then retaped with Scotch 33+. Instead of using a hot stick, he appears to grabbed it and got fried. It was established that the cutting and taping was done after the initial installation by an unknown and untraceable entity. It was a complex and drawn-out case. The Owner of the apartment complex was faulted for not keeping records of the repair, thus rendering the person with the largest portion of responsibility unidentifiable. The worker was faulted for performing the work unsafely.
