- Tennessee NEC:2017
- Semi-Retired Electrician
I have a customer that has an electric gate for his driveway. He says it has been hit by lightning several times and is very expensive to fix each time. He wants some sort of lightning protection for it and asked me about it. I don't know how to help this other than some type of extra grounding for the controller. So I'm asking for some advise on this.
I was busy doing another job for him when he asked so I didn't get to look at how the power was brought to the gate. I do know it's several hundred feet from his house to the gate. So I don't know if he has a voltage drop causing low power to the gate. I also don't know if low power would cause the problems for the controller or it's actually being hit by lightning.
He said the company that put in the gate controller and that has been replacing the parts said it was lightning. But I don't know if that is just there standard answer for problems with their equipment.
What should be done for the lightning if that is the case?
What else could be checked that would cause failure of the controls at the gate?
