I don’t do too much work with older heating systems and need some help troubleshooting an electric baseboard problem. The client has 2 Honeywell electric heat Relays connected to main panel that are tied in with 2 240V Double Pole 20Amp circuits. Voltage off breakers checks out (120V per line) and I am getting 120V off all three wires (Red Blue Black) for the Relay. At that point I thought it was a bad thermostat (Honeywell round Mercury mechanical stat) so I disconnected the stat and jumped the 2 wires to see if heat would come on. Am I WRONG in assuming that by directly connected the 2 24V stat wires the heat should kick on?
