Need some help on this one please........
I am experiencing problems with the electric igniters on a gas cooktop. The igniters (on all 4 burners at the same time) function/energize as if in the ignite position? The Knobs are in the off position.
A BIT OF HISTORY:
About a year ago, Service Call "A" finds that when microwave is on, igniters on cooktop (knobs off) go click, click, click, click......until microwave is turned off. Moving the cooktop feeders from the small appliance multi-wire branch circuit solved the problem. New cooktop power was obtained from a different multi-wire branch circuit. I suspected a loose neutrals at the time but could not prove conclusively. No bad connections or loose neutrals were found.
Now, about a year later is Service Call "B". The customer has had new air conditioning equipment installed. The FAU/coil is on the "cooktop circuit" and now the igniters are going click, click, click, click again. This time it is not the microwave causing problems, it's the new FAU????
A BIT OF HISTORY:
