guys and gals, curious to hear any methods you have been using to install electric in block walls with no finishes attached to it. Our standard procedure has always been to run with the masons, get a box cut in, install conduit at 3' intervals until we reach above ceiling and sub out, then run MC to each stub out. It is a tried and true method, just time consuming. There are locations that the block is not filled and we could fish the CMU void, but cutting a flush box in afterwards would fall on our scope. Just wondering if anyone was able to think outside the box and find a better method.
