Charlie Bob
- West Tennessee
fire suppression system. i got the rest of the wiring but the solenoid gas vale is confusing me a little.
There's 5 terminals on the reset box for solenoid. I understand power goes to it, hot to 2, neutral to 5.
from the microswitch common goes to 3 and NO to 4.
Now here it is where i'm not that sure:
It says :"install one side of the load cable to terminal 1, the other to terminal 5"
Well the gas solenoid valve has 3 wires, 2 red and one green.
-I understand that the reds are leads, but why are both red?
-Shouldn't one of them be a neutral, and be white then?
-According to the reset box diagram, the leads from the load go to terminal 1 and 5 (5 being neutral terminal), does it matter which lead goes to which terminal then?
Thanks.
Thanks.
