jaymiller
- Phoenix, AZ
Why does electricity go back to its source?
To the extent that an electric current is the result of moving electrical charges, those charges or their equivalent quantity of charge must return to the source to avoid a buildup of charge which would cause a voltage offset. That voltage offset would eventually be enough to stop current from flowing by opposing the force that is making them move in the first place.Why does electricity go back to its source?
First law of thermodynamics:
Energy cannot be created nor destroyed, just moved around (paraphrased of course).
It has to come from somewhere, so eventually is has to go back there.
Because continuous electricity must flow in a circuit, like race cars circulate on a closed-loop race track, unlike static electricity, which is more like a dragster on a linear track.Why does electricity go back to its source?
Nicely stated.
Back in the day, The Firesign Theater had a concept: Fudd's First Law of Opposition. Loosely stated, "What ever comes out, must go in."
I equate electron movement in a conductor to a garden hose filled with marbles. Push one more into one end of the hose and one immediately pops out of the other end. Not the same marble, which would take a while, but the effect is instantaneous.Electricity is the movement of electrons.
Hydraulic analogy is better then you may think. A hydraulic system does return the media to a reservoir and it eventually cycles through the system again instead of being replaced with something else.To the extent that an electric current is the result of moving electrical charges, those charges or their equivalent quantity of charge must return to the source to avoid a buildup of charge which would cause a voltage offset. That voltage offset would eventually be enough to stop current from flowing by opposing the force that is making them move in the first place.
This is one of the weaknesses of the water analogy for electricity, in that people do not tend to immediately realize that water eventually returns to its source too, via evaporation, rainfall, and a host of other background processes.
I will say in an typical AC system derived by an isolation transformer the source is the secondary coil. No electrons flow between primary and secondary, just the energy carried by magnetic fields is transferred from primary to secondary.Electricity is the movement of electrons.
Imagine a lake and a pump in that lake. The intake pipe is at one end of the lake and the output pipe is at the other. As the pump runs, water piles up on one side of the lake while a trough is created at the other. What happens? The water around the trough starts moving toward it to fill it in. As it moves it makes a smaller trough that other water fills in and so on. The lake water will flow from the high side to the low side until the lake is level again. Note that it's the nearby water atoms that are actually returning to the intake pipe (source), not the ones that were pumped to the far side of the lake. If you run the pump long enough they too may make it back, but not necessarily. They may just swirl around.
The same is true for electrons. Electrons will flow back to the source, but not necessarily the same electrons. In a network of sources and loads (like the power grid) an individual electron could start at one source and flow back to a different source. Electrons will flow toward wherever there is a deficit of electrons until all the metal atoms have all their electrons back.
A common analogy possibly valid for DC. For AC, which we mostly use, the electrons don't go anywhere. They just jiggle back and forth a tiny little bit. There is no go and return in the way it is conventionally described.I equate electron movement in a conductor to a garden hose filled with marbles. Push one more into one end of the hose and one immediately pops out of the other end. Not the same marble, which would take a while, but the effect is instantaneous.
But it doesn't have to return to the source "right away" right? We can take electrons from something, and push them elsewhere (I am thinking van degraff generator) but just only for so long until charge gets so high it jumps across or destroys whatever insulator we are using - correct or am I off base? If we had a good enough insulator, could we power something until we strip all the electrons from the source?
With static charges the electrons taken from one object would eventually have to be replaced somehow I would think, otherwise the carpet in your example would eventually have a pretty high charge on it.Basically a gigantic static charge, it will seek whatever is at a lower potential. Like shuffling across carpet and touching a doorknob... the electrons are ripped from the carpet and do not go back to the source...amiright?
It is a valid analogy for each half cycle. The individual electrons don't move very much, but the instantaneous effect I described still moves at (almost) the speed of light.A common analogy possibly valid for DC. For AC, which we mostly use, the electrons don't go anywhere. They just jiggle back and forth a tiny little bit. There is no go and return in the way it is conventionally described.
I don't disagree with near instantaneous effect. It doesn't long at all for you to realise you are being electrocuted.........It is a valid analogy for each half cycle. The individual electrons don't move very much, but the instantaneous effect I described still moves at (almost) the speed of light.
