A common analogy possibly valid for DC. For AC, which we mostly use, the electrons don't go anywhere. They just jiggle back and forth a tiny little bit. There is no go and return in the way it is conventionally described.
+1
Drift Velocity
Nicely stated.
Back in the day, The Firesign Theater had a concept: Fudd's First Law of Opposition. Loosely stated, "What ever comes out, must go in."
Why does electricity go back to its source?
I don't disagree with near instantaneous effect. It doesn't long at all for you to realise you are being electrocuted.........![]()
:thumbsup: ...........Actually, Sir Sydney Fudd's First Law of Opposition is: "If you push something hard enough it will fall over." He discovered it when he pushed his wife down the stairs.
You must be thinking of Teslacle's Deviant to Fudd's First Law: "It goes in, it must come out."
Hydraulic analogy is better then you may think. A hydraulic system does return the media to a reservoir and it eventually cycles through the system again instead of being replaced with something else.
Kind of same thing as described here.
I will say in an typical AC system derived by an isolation transformer the source is the secondary coil. No electrons flow between primary and secondary, just the energy carried by magnetic fields is transferred from primary to secondary.
Always appreciate being educated.......:thumbsup:As you probably already know.
It's the electrical energy created by the electromagnetic wave that is traveling near the speed of light down the wire, not electrons.
The electrical energy moves down the wire in one direction from the source to the load in the form of an electromagnetic wave.
Separating the electron from the atom nucleus is what releases the energy. the process called fission. Since electron is negatively charged, applying electric current could cause separation of the electron from its nucleus thus converting that energy that is usable like operating our hair dryer or kitchen toaster. It also can become destructive like "The Fat Man".
There are electrons in an atom nucleus?
Many elements have unstable conditions in outer electron shell which gives them both chemical and electrical properties that you don't find in elements with a stable outer electron shell. Simple loss of an electron(s) isn't fission. Fission would be splitting the entire atom including the nucleus, which is what is done with nuclear fission. When they split a uranium atom what is left is not uranium. When you have a loss or electrons in an element you still have same element it just is left with a positive charge and is looking to react with some other element that has a negative charge.Whenever there is energy, there is electron. An atom is composed of proton, neutron and electron. We are all surrounded by atoms. . . it is the basic building block of all matter.
In the transformer pri/sec winding scenario, magnetism happens when electric current is applied. Magnetism in itself has no energy. . . it is a force.
Magnetism within the transformer core, forces the electrons from the primary to the secondary windings through the strength of the magnetic field. As you strengthen the magnetic field the more electrons is pushed to the secondary winding.
Magnetism is essential in controlling energy and converting one energy to another.
squeeze hard enough you'll get all sorts of stuff in the nucleus areaThere are electrons in an atom nucleus?
I disagree on the transformer theory you mentioned. Yes magnetism occurs when current flows through the primary coil, but it doesn't push electrons from primary to secondary. Only energy is exchanged via magnetic forces between primary and secondary. That magnetism then "excites" the electrons in the secondary circuit and they then pass the energy on to adjacent atoms and thus current can then flow in the secondary circuit.
Happy that you asked yet?Why does electricity go back to its source?
