mtnelectrical
- Essex, New Jersey
any recommendation for a good water heater controller that works with a wifi ? heater is 208 volts 30 amps
I use Wemo with a 30A contactor. Works great.any recommendation for a good water heater controller that works with a wifi ? heater is 208 volts 30 amps
There are wifi water heaters as well as devices rated at 30 amps that can control the circuit.
If it is really desired I'd get the water heater with the Wifi because you can control the temp remotely.
Why would someone want to control a water heater via WiFi? Other than, they can.
exactly.Turning the temp down when going on a long vacation?
Mine has a control board on the top with 4 settings you can do right on the water heater. I guess WIFI would allow them to do it later if they forgot to do before they left the house. But how often would you really need to do that?
Sounds like more things to go wrong to me....
How about just turning it off? Or is that too simple?Turning the temp down when going on a long vacation?
Yes, too simple.How about just turning it off? Or is that too simple?
I forgot to mention that the water heater just has been replaced.
exactly.
These only have value to gadget junkies. Maybe someone that is obsessed with saving every tiny bit of energy they can or way to involved in being green for the planet (but those people shouldn't by nature even be interested in a tank type water heater) would also have an interest in such a product. Tank type water heater doesn't cost that much to maintain the tank when you aren't ever using any hot water. On top of that losses are only total losses during cooling season or if the tank isn't in a conditioned space (not happening here or you will have frozen pipes in the winter). During heating season those losses just supplement the heating system.
I recently seen a garage door opener with wifi abilities. What is so important about needing wifi to communicate with your garage door? Sure you might be able to remotely open the door from half way around the globe, but how bad is the need to do so? That same GDO I was asked to connect a new "wired wall control" for it, as the old one stopped working. New one didn't work either - problem in the main unit - the old wall control did work on the second door opener they had. What was wrong with the traditional simple normally open contact that we used to put inside the garage as a control? I can understand something with additional security for an outdoor control. I ended up fixing that one with a wall mount wireless controller. Sends same kind of signal as the vehicle remotes, just designed to mount on the wall. Was a lot cheaper then a new circuit board for the door opener.
again vacation homes.How about just turning it off? Or is that too simple?
Yes, too simple.
When you come back and turn it on again - that is for some reason the time some component will fail.
A simple ON-OFF switch??Yes, too simple.
Thing with unoccupied is that things seem to deteriorate pretty fast. I don't care what it is, they just do.Sorry to hear that.
There are Zwave 30 amp controls , they look like a intermatic timer,
Some from a company called Sinope
There are many.
If you don't already have a home automation platform I would look into one that has features you desire and go with that.
Hummm , Maybe they have a vacation rental , want to turn up the heat so it is ready when a guest arrives.
In a vacation home it can go months unoccupied , why would you want to waste the energy like that?
Everything will fail at some point. I think the benefit is great.
:thumbsup:Who is kidding who? With any rental property if you are in your right mind you are either a reasonable distance away or you have somebody who is to look after it. That person will open it, close it, clean it and make sure guests are behaving themselves and not trashing the place. So a simple on-off switch to turn the heater off if the place is to be vacant for a length of time and on again when it's rented is just fine.
A vacation property assumes one occupant so it's even simpler. Turn it on when you arrive and off when you leave just like the lights.
I really don't see the need for some Millennial generation toy.
-Hal
:thumbsup:
Unless you are going to need to shower as soon as you arrive, shouldn't be that big of a deal to turn it on when you get there. Might be other things you turn on as soon as you get there as well (other then lights).
Water heater tank that is already at room temp doesn't take as long to heat to 120-125 deg F as it takes to heat up freshly filled tank of only 55 deg F water either. Half an hour or so you probably can take a shower - might not be able to be a long shower but can have reasonably warm water. Bath is out of the question until tank is much closer to set point, if you want a really warm bath.
You obviously have no idea how inept and useless some rental guests are. Also how would one know if they guest turned the heater off?
I do, but my comment was on "vacation houses" which is one branch this thread has grown.You obviously have no idea how inept and useless some rental guests are. Also how would one know if they guest turned the heater off?
Switch rooms and substations are generally unoccupied. Same with pumping stations.Thing with unoccupied is that things seem to deteriorate pretty fast. I don't care what it is, they just do.
