Smbat Petrosyan P.E.
New member
Who can help with finding out necessary pressure for copper to copper electrical connection. Is tehre any code or standard?
? If I were to guess as to what you are referring to that would be dependent upon the terminal selected and the torque value as specified be the terminal manufacturer.necessary pressure for copper to copper electrical connection.
Whats the matter, is your toque wrench missing the not so tight to strip the threads setting?Originally posted by petersonra:
A: On the threaded stud bolt we recommend to torque until tight and not so tight to strip the threads.
What the hell kind of answer is that? LMAO.Originally posted by petersonra:
The NASCAR motto is "torque it down till it strips then back it up a half-turn".Originally posted by don_resqcapt19:
I always thought the correct method to torque was "to tighten until it breaks and backoff a 1/4 turn".
