QES Senior Member Location California Oct 14, 2008 #1 I am mounting an 1200A 480V ATS right on the edge of a door way. I did not find code with this issue. Any problem here?
LJSMITH1 Senior Member Location Stratford, CT Oct 14, 2008 #2 You might want to call your local inspector. There may be a setback requirement from the door frame.
charlie b Moderator Staff member Location Lockport, IL Occupation Semi-Retired Electrical Engineer Oct 14, 2008 #3 I don't see an NEC issue with this installation. I presume that you have the proper working clearances on the other side, and in front.
QES Senior Member Location California Oct 14, 2008 #4 The ATS( front access only) is mounted in the corner of the building with 5' front working space.
