- Lockport, IL
- Retired Electrical Engineer
Re: electrical ghosts
But current will not go into loops and head "everywhere but back to the source directly." If current finds two roads ahead, and if one leads back to the source and the other leads away from the source, then all the current will take the first road, and none will take the second. The push is towards the source. Current cannot flow upstream against the push that is pushing it back to the source.
This is where you are going wrong. Current moves because voltage pushes it. The push comes from the source, and the current is being pushed back to the source. If there are multiple paths that lead back to the source, then current will follow each and every one of them.Originally posted by honeyfarmer:. . . however multiple paths/bonds between neutral +ground . . . are not a quicker path but a corrupted path which current does not flow back directly to source but go in loop runs and every where but back to the source directly
