Dave_PE said:A lot of jurisdictions consider an underground service lateral running below the building foundation to still be "outside" the house......as long as you have a MCB at the panel, then no exterior disconnect switch is needed. Fire dept. not too happy about it, but the AHJ allows it.....
where the panel will be located more than ten feet,once entering the house
danickstr said:This had me wondering if the metal meter box has to have a ground wire on it, esp if it is connected by pvc, or if that is not necessary. i have not put one on in the past, but wasn't sure if this was still the case.
